tamte you can use POP Force, just limit the group to the points you want to pull and animate the force value
Thanks for the answer. I built the DOP net but I don't know how to make group from two corner point in there and where I should connect the force? In Particle Force? See attachment.
- you can still use Vellum SOP if you want to, just dive inside, and you can place DOPs - as a group you can put point numbers directly or point group that you can create in SOPs before
tamte - you can still use Vellum SOP if you want to, just dive inside, and you can place DOPs - as a group you can put point numbers directly or point group that you can create in SOPs before
I would never figured out this by myself! So simple and beautiful! Thanks man!
