Hi all.
I am trying to setup a network to render via hserver.
I have all of my render nodes using NFS to access to the file server.
I have checked the paths and all seems to be working properly, in fact I don't get red buckets or errors from the hserver when trying to access to textures.
Instead I am getting complitely grey buckets when using texture maps.
When I use only procedural textures the netwrok render work perfectly, but when I use texrture files it fails.
I have attached an image with the render failed.
Anybody have suffered similar problems?
Using H 8.1.705, Linux
Problems with hserver
4477 5 1-
- lisux
- 581 posts
- lisux
- 581 posts
Well the problems seems to be solved.
The render nodes are using H 8.1.666 and the master node H 8.1.705, so the different version couse the problem.
Another doubt that I have is if anybody can tell me the different “secret” parameters that the hserver command can use.
for example if you type hserver - to see the parameter the -d option doesn't appears, and this option launch hserver in debug mode.
Are there more options like this, specially are there any option to save a log from the hserver in a file?
Un saludo
Best Regards
Pablo Giménez
Best Regards
Pablo Giménez
- edward
- 8108 posts
If you haven't checked this page out, it might help you:
http://odforce.net/wiki/index.php/MantraRemoteRendering [odforce.net]
- lisux
- 581 posts
edwardThanks Edward, yes I checked it before posting here.
But there aren't relating to hserver “secret” options
Un saludo
Best Regards
Pablo Giménez
Best Regards
Pablo Giménez
- JColdrick
- 4140 posts
- lisux
- 581 posts
ops:
