another PoP question from me ;-).
I want to store some Data on a per particle basis, such as a the ID of an particle which are connected and the restlength of the string between them.
i didnt find anything in the documentary under pop's, and other important thing is how to make this data available between the frames, so my calculated values are stored in frame X and should also be available in frame x+1.
thx in Advance
Sebastian
API - Adding Data to Particles
3158 3 2- Infernalspawn
- 229 posts
- Le_monkey_butt
- 166 posts
Hi Sebastian,
Here an example, I used sometime ago. It is dirty but that worked.
In my case I needed some data at T-1 so I stored it as another attribute
POP_ContextData* data = (POP_ContextData*) context.myData;
int density_off;
int prev_dens_off;
// create your data.
density_off = data->getDetail()->addPointAttrib(“density”,sizeof(float),GB_ATTRIB_FLOAT,0);
prev_dens_off = data->getDetail()->addPointAttrib(“prev_dens”,sizeof(float),GB_ATTRIB_FLOAT,0);
// To access your new data
float *my_density, *prev_density;
my_density = (float* )ppt->getAttribData(density_off);
prev_density = (float* )ppt->getAttribData(prev_dens_off);
int density_off;
int prev_dens_off;
Time to get out of this messy world.
- Infernalspawn
- 229 posts
- Le_monkey_butt
- 166 posts
