I'm creating a Particle OP and actualy i got lots of parameters. I want to clean up all the stuff and group them into different tabs. But how can i create different tabs, theres no description in the “Using Parameters” part of the HDK - documentation.
it would be fantastic if somebody has a clou.
thx in advance
Sebastian
API - how parameter in seperate tabs
3150 2 1- Infernalspawn
- 229 posts
- Le_monkey_butt
- 166 posts
Hi Sebastian,
Here an example:
When you declare your parameter the first one will be the switcher/tab
static PRM_Name names =
PRM_Name(“sw” , “SW”),
Then…
static PRM_Default switcher_label = {
PRM_Default(2,“tab1”),
PRM_Default(3,“tab2”),
PRM_Default(4,“tab3”),
the number is the number of parameters you want to include in that tab.
Then:
PRM_Template
POP_YourPOP::myTemplateList ={
PRM_Template(PRM_SWITCHER,
3, // Number of tabs
&names,switcher_label),
well I think that is it…
if you have a problem, let me know.
Here an example:
Then…
Then:
PRM_Template
Time to get out of this messy world.
- Infernalspawn
- 229 posts
