Is it possible to control a edgecusp after subdivision ? What I would like to do is being able to let edgecusp use the same edges defined in creaseSOP.
crease–>subdivide–>edgecusp
edgecups after subdivide?
4096 4 0- Mikael_Amion
- 129 posts
- edward
- 7733 posts
- Mikael_Amion
- 129 posts
Thanks for your reply Edward but grouping edges is one of the the things that I have not figured out how to do in Houdini. Is it even possible? I think I´ve seen some workaround script somewhere but no luck really. Or do you mean the creaseweight attribute on vertices? I dont know how to group that either.
Any help in that area is much appreciated
- edward
- 7733 posts
- Mikael_Amion
- 129 posts
Oh yeah, thats what I´m talking about It wasnt clear to me at first but the following procedure give desired results.
geometry–>crease–>subdivide(Generate Creases)–>edgecusp(crease group)–>delete(crease group)
it is actually equal to hard edges in other packages. The nice thing about it is it totally procedural and one can also pipe the crease group into polybevel and get fine control over edges.
