Hi
am trying to create a vortex kind effect am using a curve to guide my velocity and get it into my pop network using sop geometry
since adding the node and connect it to my vortex node every thing go as fine
but when ever i name my curve in the sop the software crashes and shutting down
am using Houdini 17.0.352 is it a bug with this version or its my mistake ? I test it with multiple machine same result
any suggest could help
thanks
issue with sop geometry
1390 2 0- shrifazmy
- 19 posts
- Midphase
- 833 posts
If it's happening on several machines, it's probably a bug and you should file a bug report.
>>Kays
- jsmack
- 7770 posts
