Snippet VOP node : "outer code parameter " - accepts what input or type ?
1617 2 1- papon
- 34 posts
- tamte
- 8554 posts
- papon
- 34 posts
tamteit seems you are an experienced houdini artist . thankYou .
the tooltip describes it quite well
simply put a code in there that you want to be executed before (outside) of the body of the main shader function
what can be deceiving is that it has just a single line UI, but you can type a multi line string in there
Edited by papon - July 19, 2019 11:22:44
