Remove all signs of (Pre-Installed) RenderMan in Houdini Vanilla
2131 1 2- oddvisionary
- 1 posts
- AslakKS
- 160 posts
The preinstalled “bits” should get removed when you have RenderMan 22 installed/loaded. It gets removed here atleast. You might need to check if RenderMan is the first thing in your Houdini path (there are some issues if its not first).
You can check that in the Python Shell. with
hou.getenv("HOUDINI_PATH")
Edited by AslakKS - Aug. 11, 2019 02:43:00
