Houdini 8.1.655, Linux
The sop pathname in a wireobject dop doesn't update when the geo it references is renamed.
I have a subnet with a geo and a dopnet in it. The dopnet contains a WireObject Dop, which has its SOP Path parameter set to “../../geo1/INTO_DOPS”. When I rename “geo1” to “inputCurves” the SOP Path param doesn't update (because, it appears, the blue display flag on the dopnet is off). If the display flag on the dopnet is on, then the pathname updates ok.
The pathname should update regardless.
cheers,
ben.
BUG: WireObject DOP doesn't update path to renamed Geo
2337 1 0- ben simons
- 387 posts
- edward
- 7726 posts
