Generative industrial Concept Design, your take on this example...
   8212   13   4
Looking at some Fernando Magalhães examples, i was wondering how you will approach it yourself?
Do you think he is using some premade bash 3d models kits then distributed, wrap after on another geo, may be fragmented by a Voronoi kind of noise?
Or is fully procedural even for the rivet placement and so?
________________________________________________________________
Vincent Thomas   (VFX and Art since 1998)
Senior Env artist & Lighting & MattePainter & Creative Concepts
 http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
46598614_2312811328793854_8158027196041003008_n (1).mp4 (3.3 MB)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
Cop patterns
to Uv
Slice with boolean by Uv (vex code on odforce)
extrude those panels _ VDB from polygons (than CIRCLE everything)
then modification in Zbrush
then WHo Knows
You have already this on odforce he just found examples and put everything together
you might want to check this out
https://www.cgcircuit.com/tutorial/procedural-hardsurface-design-in-houdini [www.cgcircuit.com]
Training Lead
www.sidefx.com
Hey,
None of these images I did using any boolean, vdb, voronoi fracure, premade kits or zbrush. And also I can`t write a line in vex.(I do everything is vops).
Also Goldfarb is doing a great job. Check his stuff.
check this as well
twitter.com/Simon_Houdini
and rohan dalvi is doing pretty cool stuff as well!
thanks
Fernando
First of all, since Fernando is a good friend of mine, I can assure you that everything he does is fully procedural and no premade geometry was used to generate the final result.
Secondly, I don't like it when people repost other people's work without crediting it. You posted his work on your LinkedIn profile and it looks like you claim it to be your own. You either state that you didn't create it and credit Fernando correctly or delete the post entirely.
srletak76
Thanks, could you elaborate a little more for the boolean by UV please?
I ‘m not sure i understand the relation you are speaking about and i couldn’t find anything on odforum for now
Cheers!
it sounds interesting I now
https://www.instagram.com/cnc_verkstad/ [www.instagram.com]
I posted those stuff on Instagram little snippets how and what ( to make generative Art) and you have on odforce in my gallery username-srletak Nature fun pointvop ( you just need to play a little bit with those files ) …but soon I'm gonna post my file so that everyone can have fun ..
Have a nice day
You have a new follower now, your work is diverse and always inspired, it's easily one of the best i have crossed by, thanks for giving to our world a little more beauty
I will research for this example file and vex snippets to see if i could find then.
For the “boolean by Uv” you mean using the uvsample ?
Thank you for the kind words.
You can use uvsample or projected COp patterns endless possibility, soon I'm gonna post hipnc just to fine adjust
you have here exactly the same method just need to putt altogether…
same technic
https://www.youtube.com/watch?v=VOPBZMbpMMo [www.youtube.com]
texture
https://forums.odforce.net/topic/43704-creating-texture-files-procedurally-and-backing-to-desk/ [forums.odforce.net]
Patterns loops technic
https://vimeo.com/235819159 [vimeo.com]
and old file from odforce ….have fun
Edited by Librarian - Oct. 6, 2019 12:36:24
slicedBoyFromUVs.rar (47.0 KB)
Very smart, thanks you so much
why should i buy puzzle game on the apple store, houdini could hold my breath for one life !
Here is a very basic concept of extruded voronoi tiles.
voronoi_extrusions.hipnc (144.9 KB)
Regarding the rivets: You can position those by
  • removing shared edges with divide node,
  • removing inline points by a generous distance and
  • extruding inwards with polyextrude.
  • polyframe for normals and copy SOP.
voronoi_extrusions_rivets.hipnc (161.8 KB)
Konstantin Magnus
- This is cool thanks you so much!
I believe it will make sense to also be able to split/cut my underground model with a cop output or a given input file instead of having all the time to rely on a Voronoi noise.
Don't you think so? any suggestion?
- I was also thinking to use volume and boolean to make a sharp industrial look denting when one mesh has to be inserted and blend with another one or the base surface. Do my words make any sense to you?
- Is it not possible to find possible realistic placements of the rivet with the measuring node, edge distance and so?
shrinking the edge of a define group of area?
- I'm wondering but apparently (i may be wrong) Fernando is not using pre-made block of kitbash geo, will you agree?
Im still at an early stage, but ideally i believe the best would be able to blend and combine both.
Have you seen some example of this? Just curious…
Cheers guys, you smart minds
Thanx Magnus for Basic Stuff
