Hi guys I've been trying this for a long time, but the only way to export lines from Houdini to Max seems to be through Igs format. Max doesn't like Igs coming from Houdini so i have to convert them to DWG with Rhino. When i export splines from Max to Houdini, i use Alembic which works fine, but doesn't work the other way round. I was wondering if someone had any luck with this
Hi Jsmack. Yes I am aware of the engine, but I need to be able to export them to a file format that someone who doesn't have the engine (and Houdini) will be able to open without problems. I can try to convert them from max using the engine, but I'd like to avoid additional steps.
