Hey, I'm just learning Houdini and coming from a background in other 3d applications, one thing that I'm really struggling with is controlling my pivot points. Any advice would help!
If there was a node that could re-center a pivot to object center it would fix all my issues I feel but I haven't found it.
Here's the current problem with my pivot which probably has a simple solution but I could think of it yet….
I'm trying to copy a screw in a straight line but have a random rotation, but each time it copies it will rotate from orgin and not object center and creating a curved copy instead of a straight line.
Pivot struggles
4512 4 1-
- 3dspline
- 36 posts
- toadstorm
- 409 posts
The better way to copy things and apply unique transformations to each copy is through the use of template point attributes. The Copy to Points SOP will read these attributes on your points and transform each generated copy automatically.
I wrote this a while back but it's a pretty thorough guide on how these attributes work: A Long-Winded Guide to Houdini Instancing [www.toadstorm.com]
- BabaJ
- 2171 posts
- robsdesign
- 240 posts
- 3dspline
- 36 posts
