How to access a USD stage from SOP's in a wrangler
   2994   3   2
Hi
So I am trying to access a USD stage from a SOP wrangler, been trying everything but no luck, the other way around works fine with the “op:/” syntax in a LOP wrangler, is it not possible or do I need to use something as my stage instead of the “op:/” syntax ?
And maybe if its not working in SOP:s, the functions needs be hidden in any SOP wrangler context?
Cheers
Edited by jens_martensson - Jan. 24, 2020 21:48:48
Jens Martensson
Effects Supervisor @ Rise VFX
if I remember correctly the intention is to make them work with lop path ( through op: ) as well as .usd file path, not just input number
so ideally that would happen rather than hiding them from other contexts
Edited by tamte - Jan. 26, 2020 01:29:40
Cool, I will just wait for the update for op path and usd file as an input
Cheers
Jens Martensson
Btw, that's the RFE 94713.
