Weird slider behave
   794   2   1
I have a pretty weird problem with sliders. My last animated frame is 168 and if I slide the “Top Position on Circle” or “Bottom Position…” they work as should, but if move time line to frame 280 and try then slider, they don't work anymore. Animating slider does not work neither. Seems to be a bug because this behaving doesn't make any sense?
bug.hiplc (1.6 MB)
not really a bug
your /obj/chopnet1/object1 (and object2) range is set to 0-10s at 24fps so it will stop updating the value at 240
if you set it to use Current Frame you should be good (also you can set their fps to 240 to match your other constraints)
FX Supervisor
Method Studios, NY
Thx! I had no idea about this setting there. I got it work now!
