Hi!
I want to use mask field of the Gas Surface Tension DOP to control surface tension with an attribute, but whatever I try seems to have no effect. I'm using the volumefromattr sop to create a vdb and try to source that in dops, but no luck. Any help would be greatly appreciated!
Felix
Gas Surface Tension Mask
1661 3 1- Kaiserlicht
- 18 posts
- Kaiserlicht
- 18 posts
- animatrix_
- 4531 posts
Your setup is failing to import the mask field because you are trying to match to density field which is a non-existent field in standard FLIP. If you set this parameter to “surface” which is present in a standard FLIP sim, then it will import your mask field properly.
- Kaiserlicht
- 18 posts
Thank you very much for your help. I'm still struggling to get this to work. I've set the “field to match” to surface in the volumesource. Although I really don't understand why, because by default when sourcing flip surface it's set to density. This whole dops/field thing is sooo confusing.
Another error (I suppose) was that I was sourcing my mask only on the first frame, I've set the activation to constant now. But still it's not behaving like I want it to, which is blending in the effect of surfacetension from one direction. Now the fluid is exploding in a weird way…
Any more help would be fantastic!
