Q: Syntax for setting properties in karma/husk command line
   2739   2   2
I'm feeling a little dumb on on this one, I can't figure out the syntax to set the properties on the command line for karma/husk.
Also, why is DOF on by default? Since it needs to be off 99% of the time, maybe “off” for the default is better?
Peter B
Peter Bowmar
____________
I don't think there's a way to specify arbitrary properties on the command line. Right now, the only way is to sick a RenderProperties.json file in the search path… Not the most convenient.
And yeah, there should likely be a command line option to disable both motion blur and DOF (which are both on by default). It's really nasty when importing a camera that has fstop set to 5.4 (the USD default is 0 - which is no DOF).
Thanks Mark, it's obviously easy enough to work around inside LOPs, just thought I'd mention it.
Peter B
Peter Bowmar
____________
