vex: creating ordered menu from array values
   3834   3   0
Hi!
I have a detail string array with values: A, B, C, D. I would like to use a detail wrangle where I can use a dropdown menu to choose what value I want and ouput into my s@chosenLetter.
I already know how to use an integer to chose a value in the string array.
int chosenIndex = chi("chosen");
s@chosenLetter = s[chosenIndex]@myArray;
The part I'd like to understand is how to populate the menu (ordered menu?) with the values of my array so 0=A, 1=B, 2=C. etc. Can this be done automatically?
-Olivier
Edited by olivierth - Feb. 23, 2020 13:47:47
-Olivier
you can use Python under the menu tab of the ordered menu
('s' is the name of the string array), but you have to convert the ordered menu to string (or the indices are -1).
import numpy as np
node = hou.pwd()
geo = node.geometry()
W = geo.stringListAttribValue('s')
n = len(W)
L = map(lambda x:[str(x), W[x]], range(0,n))
Q = np.array(L).flatten()
return Q
py_ordered_menu.hipnc (87.0 KB)
olivierth
I guess you meant:
s@chosenLetter = s[]@myArray[chosenIndex];
Edited by tamte - Feb. 23, 2020 17:35:19
Aizatulin: Ah! I didn't think I needed to use python for this. I'll try it out. Thanks!
tamte: oops… Thanks!
-Olivier
