Simple GLSL Shader Example?
   7642   10   6
I'm trying to learn how to write custom viewport shaders in GLSL, but couldn't find any up-to-date example. I read the relevant help pages (OpenGL Shaders [www.sidefx.com] and custom viewport shader [www.sidefx.com]), but still don't know how to implement basic things such as hooking up a diffuse map. Can anyone point me to a vanilla example?
Many thanks!
Still wondering about this.. Please anyone?
Install sidefx labs, there's several example viewport materials in there that hook up to texture slots.
The default GLSL shader produced with the steps listed in the second link you provided (https://www.sidefx.com/docs/houdini/shade/glsl.html) seems to work for me.
I tweaked the fragment shader to set the diffuse color to green, and the sphere appears green in the viewport. See attached.
glsl_shader.hip (105.4 KB)
Thanks for the helpful replies mestela and rafal!
mestela
Following your suggestion I looked at Labs Quick Material. It's indeed helpful, but it's also the only one I found. Are you referring to any other labs materials that I'm not aware of?
The matcap one is super simple and clean, good starting point. The flow map visualiser is right at the other end.
That's great, thanks again! Btw do you plan to do the ‘viewport preview and GLSL’ section on cgwiki any time soon?
Heh, only if the need comes up from my end, and the need hasn't come up.
rafal
hi,how to enable to see the final effect??I got gray ball always
https://forums.odforce.net/topic/43407-the-book-of-shaders-in-houdini-vex/ [forums.odforce.net]
I posted here at the and of the Topic link
https://serano-vfx-lab.hatenablog.com/entry/2020/07/13/170212 [serano-vfx-lab.hatenablog.com]
Here you have something that can be useful for learning
https://github.com/raganmd/BOS-in-TouchDesigner [github.com]
plus some file that I have Fun in process of learning
Have Fun
Edited by Librarian - Jan. 22, 2021 04:02:54
test.rar (30.2 KB)
Librarian
Have Fun
thanks your example,but still can not know how to change the effect by changing the parameters...
