It's houdini 18
I know that Fit vex ‘comma’ goes in between min and max, but I have to type ‘.’ instead of ‘comma’ here, so no errors occur. What's wrong with this?
Fit vex is weird
1310 3 0- EDITH
- 19 posts
- Drasko Ivezic
- 104 posts
fresiaa
It's houdini 18
What is the whole expression? I feel something is missing from your image. But it has to be dot in the float values, not comma, so make sure that the expression is not maybe interpreting this as if some element is missing.
- tamte
- 8635 posts
- EDITH
- 19 posts
Drasko Ivezicfresiaa
It's houdini 18
tamte
your expression is:fit(rand(stamp("../copy1","id",0) + 0,47), 0,1,-95,95)
the problem is + 0,47
should be + 0.47
side note: it's not VEX but Hscript
Thank you for your quick reply. I've solved it.
