Polyframe generated normals change direction with scale
   3213   2   1
I have an issue with the normals that are generated by the polyframe node changing direction when part of the curve is scaled. Not sure what's causing this issue or how to fixed it.
I attached a test scene as it's pretty hard to explain in text.
PolyframeIssue.hip (110.8 KB)
here…added a reverse, polyframe so that BOTH curves are consistent with N in the merge
then…the crucial detail: in your clean, do NOT remove the N
vu_PolyframeIssue_Fix.hiplc (107.9 KB)
please use orientation along curve SOP in Houdini 18
poly frame can generate many types of frame but except curve
I often use poly frame SOP to generate frame from UV or other attrib, but it is not good at generate frame of curve
Edited by zengchen - April 1, 2020 00:17:21
My Youtube Channel [www.youtube.com]
