I’m new to houdini,so I don’t know much.
Is there a way to import particle fluid surface (water fluid displacement) into a displacement texture map?
For example, oceanEvaluate node have “export to texture” tab and I can export displacement texture for FFT ocean.
Is it possible to do the same for a particle surface mesh?
Create displacement map from "ParticleFluidSurface"
1772 1 0- kripto289
- 3 posts
- mikelyndon-sesi
- 394 posts
