Copy different sized spheres along a curve
   3273   4   0
Bit of a challenge. I'm trying to copy spheres with different pscales along a curve. I want the spheres to sit together as if they were on a piece of string, no gaps! I feel like this should be easy but I can't figure it out.
Do you mean this effect?
My Youtube Channel [www.youtube.com]
This is exactly what I mean! What's the input to your scatter look like though? I'm not getting the same results. Thanks zengchen!
here is the hip file
hope you like it
it must open with Houdini 18….
Edited by zengchen - April 25, 2020 11:13:54
test.hiplc (94.5 KB)
Your solution was good zengchen and solved the challenge I posed but I found I needed some more options like the ability to specify the sizes of the spheres and have a bit of overlap if I wanted. I came up with this:
Edited by lloydwood - April 26, 2020 06:14:53
curve_pack.hiplc (97.3 KB)
