Hello there, I'm following Applied Houdini Rigid II.
Here's the part on cache of each voronoi pieces to disk, before cache, attached a delete node to select each piece based on their attribute “class”.
What puzzled me is in the tutorial, the group in delete node is ==> @class='$F', it seems malfunction in current H18.The attribute locked on @class=0 on whatever frame.
Could someone explain the difference between “$F” and $F, it seems really make no sense to use “$F” at first glance.
So I use ==> @class=$F instead, it turned out to be good, with one piece shown and others deleted, cool!
But!
Since $F start from 1, the @class start from 0, thers's one piece missing.
On consider of this I typed in ==> @class= ($F-1), the node stop working, in the geometry spread sheet, there're attribute on class=0 and class=1.
Plus, when I change it to ==> @class= ($F), it also not worked, but in the geometry spread sheet, there's only attribute on class=0.
How could I get the 0-99 pieces based on frame 1-100 without changing the attribute order?
Selection expression based on $F | Applied Houdini Rigid II
1568 2 1- Jimmy_Fan
- 21 posts
- tamte
- 8602 posts
it's probably not
for more complex expressions you will need to use them though, so :
@class='$F'
, but @class=`$F`
you need to use ticks `, not quotes ' to evaluate string as expression, however simple variables are expanded even without them therefore @class=$F
will workfor more complex expressions you will need to use them though, so :
@class=`$F-1`
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- Jimmy_Fan
- 21 posts
tamte!!!
it's probably not@class='$F'
, but@class=`$F`
you need to use ticks `, not quotes ' to evaluate string as expression, however simple variables are expanded even without them therefore@class=$F
will work
for more complex expressions you will need to use them though, so :@class=`$F-1`
That also explain the Error in my file cache directory expression, the string expression should always be in ticks``, not quoto''
Thank you very much !
