The same shader works with maya but not houdini
   3188   2   0
I have a shader works with maya but not houdini, it seems the uv coordinate problem.
I can see the uv from the file sop, and I can see the uv is correct from the uv viewport, but when I render, the uv coordinate works bad. It seems that the UV didn't pass to the shader.
here is my file.
zhu_color_512.zip (290.6 KB)
^_^
maybe add and attribute SOP and in the renderman tab map uv to st
I had tried that, used attribute sop to map uv->st, but still not work… I need help….
^_^
