Is it a stable configuration? I've implemented arcsim's remeshing mechanics as a sop-node, but it leads to high unstability durig performance in sop-solver in dop network. Of course, I try to keep attributes consistency, and when it is no remeshing performed (but geometry passed through custom remeshing sop internal paths anyway) - everything goes fine. Does cloth solver/object keep some topology-oriented data? After any remeshing attempt next cloth solver execution crashes almost each time.
Thank you.
Cloth Solver + SOP Solver as a remeshing post-process
1359 3 0- JOEMI
- 128 posts
- tamte
- 8551 posts
- JOEMI
- 128 posts
- tamte
- 8551 posts
JOEMIyes, currently it's up to you to manage the constraints
It leads to massive reconstruction of constraints geometries, as I seem, it fears me really.
as without knowing certain info and assumptions there is no way to rebuild Vellum constraints since you can mix and match them as you please
so for now you have to handle any assumption based constraint setup within the solver yourself
Edited by tamte - May 24, 2020 20:46:44
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
