I need to sift through quite a lot OSM Data and it'd be great if the geometry spreadsheet would jump to the corresponding row when I selected a primitive, so I don't need to scroll and check numbers manually.
Thank you very much
Can I sync the geo spreadsheet with my viewport selection?
1216 2 0- hghtch
- 5 posts
- Enivob
- 2536 posts
Make your selection in the viewport and then bring up a geometry spreadsheet. Click the dropdown for View and activate Only Show Selected.
Make sure to turn this off after you are done. It's kind of like pinning a panel, if you forget to turn it off, you may not be looking at the data you think you are.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- hghtch
- 5 posts
