Hello
I do not understand why in att wrangle on details @myend = detail(“op:../Area1/”,“end”); works
and on attr create I can't use as value detail(“op:../Area1/”,“end”) to create a new attribute with it.
If someone can explain, please.
thanks
detail att wrangle / att create
4863 10 0-
- innocent
- 35 posts
- tamte
- 9429 posts
- innocent
- 35 posts
- innocent
- 35 posts
if I follow this :
In the expression language, there are two named functions to get detail attributes, `detail` and `details`. The first returns a float and takes an index into the attribute (so you can get components of a vector). The second returns a string and has no index.
-> to get string
Thus, there are some changes needed
1) A terminating backtick.
2) Use details, not detail.
3) Remove the 0 parameter
`details(“../set_dissolve_string”, “edge_string”)`
so to have a float, should be :
`detail(“../Area1”, “end”,0)`
it's not working on channel parameter (hda)
-> to get string
- jsmack
- 8188 posts
- innocent
- 35 posts
- jsmack
- 8188 posts
- tamte
- 9429 posts
“../area” is not the correct path, your area node is a child of your hda so “./area”
and in your first parameter with absolute path you are not using correct quotes
then the third one will be the only one that is not supposed ot return the value
""but “”for some reason as if they were pasted from somewherethen the third one will be the only one that is not supposed ot return the value
Edited by tamte - June 23, 2020 00:24:28
- innocent
- 35 posts
- tamte
- 9429 posts
not sure what you copied and pasted, I still see incorrect relative path “../area” on your screenshot
PS: I replaced just the expressions on the hda instance parameters, I didn't modify the defaults in the HDA definition, so those default values were still your old ones
Edited by tamte - June 23, 2020 01:22:27
- innocent
- 35 posts
