run simulation via command line
   4202   4   1
Hi, it's probably a very noob question but i cannot find a proper documentation online.
I'd like to run a simulation on Linux and save the output files and the log in specific folders.
I created a dop and i was able to run the simulation (and save the outputs) using GUI buttons in Houdini.
How can i reproduce all this via command line?
Here's my command line
/opt/hfs18.0.499/bin/hbatch /home/ciara/Documents/Houdini_test/myscene.hipnc
Thanks for the help
simulation command line.png (404.7 KB)
You can use the same command-line:
To see all the switches, just do:
hbatch --help
Sean
Sean Lewkiw
Machine FX - Cinesite MTL
thantks mrCatfish. i tried your solution but i encountered some issues and error messages. What am i doing wrong?
1st attempt
/opt/hfs18.0.499/bin/hbatch /home/ciara/Documents/Houdini_test/crashMan.hipnc
hbatch Version 18.0.499 (Compiled on Jun 16 2020)
WARNING: Entered non-commercial session mode.
2nd attempt
/opt/hfs18.0.499/bin/hbatch /home/ciara/Documents/Houdini_test/fluid.hipnc
/ -> /opt/hfs18.0.499/bin/hbatch /home/ciara/Documents/Houdini_test/fluid.hipnc
/opt/hfs18.0.499/bin/hbatch (4): Command 'f' not specific enough
3rd attempt
/opt/hfs18.0.499/bin/hbatch -f start 1 end 20 /home/ciara/Documents/Houdini_test/fluid.hipnc
Unknown file type start
Unknown file type 1
Unknown file type end
Unknown file type 20
You have to send commands to hbatch, either by piping a command file or using -c on the command line.
e.g.
$:/hip> hbatch test.hip -c "render /out/geometry1 -f 1 20; quit;"
hbatch Version 18.0.460 (Compiled on May  8 2020)
Rendering geometry1
$:/hip>
hbatch is just houdini without an interface. Look at the help for hscript for how to script a non-gui session. There's also hython if you prefer to script in python.
Edited by jsmack - Aug. 6, 2020 16:46:04
nice, it worked. Thanks
