Import Import Block: what does it mean?
   1110   0   1
Hi guys,
in the Type Properties doc-page we read this:
To import an import block, use the special token importblock, followed by a colon ( : ), followed by the Label of the import block you want to import.
Now I don't know what this means. Of course what I hope that it means is this: once you have specified an import block with op, token, mask and all, you can just import that import block from a higher node and there's no need to ‘Refresh Imports’ on the higher node once you refreshed them on the lower nodes (after having added parms to the node being imported, or having changed the parm-mask on the Import Settings, for example)
But whatever it means, it does not seem to work.
In my sample-hipfile I made a custom import block for a sphere on a ‘sphere’ hda, and on a higher hda called ‘spheres’ I try to ‘import the import settings’, but I get this error:
I tried some variations like this, but nothing worked:
importblock:ImportBlock - Sphere Node
importblock:folder0:ImportBlock - Sphere Node
folder0:importblock:ImportBlock - Sphere Node
Hope someone knows this and can inform me,
Edited by OdFotan - Oct. 18, 2020 19:22:44
Screenshot 2020-10-19 at 01.17.58.png (19.2 KB)
importimportblock.hipnc (114.3 KB)
