Hello again,
I'm trying to route my shaders so they are not dependent on the drives I download the jpg files into. All my Jpgs for my shaders are in a school drive from the school computer (N). How do I make a file with shaders that works independently and can be transfered from drive to drive? (right now in the texture map setting i would have something like, Nground.jpg
Thanks ahead of time. Sorry if this may be too obvious.
Cory
Shader Pathing
3048 2 1- 3DTransformer
- 32 posts
- graham
- 1908 posts
- pbowmar
- 7025 posts
I'd recommend variable idea also.
Don't forget, you don't want to use Jpegs as textures in Mantra! Convert them to .rat format. Your renders will be faster, higher quality and use less memory. You can convert them using the Houdini Command Prompt or just load them in Mplay and save them as the same name but with a .rat suffix.
Peter B
Peter B
