Hey.
I'm currently sweeping along a curve using a custom input. But on the ends of the curve the sweep intersects with the part that isn't as elevated as the rest, causing a really ugly sharp edge to stick out. I'd love some help with fixing this.
Can't figure out how to fix parts of my bridge intersecting
1096 2 1- Karl_oa
- 4 posts
- vusta
- 555 posts
your workflow is very inefficient.
If you know you have repeating geo in you workflow then always do heavy lifting just ONCE, then copy the result a million times if you want to. So in the cleaned up file I've done only ONE side
of the bridge…once that's sorted (and it is easier to debug with less merging and looping and the kitchen sink attached to it) then copy it across to the other side.
I haven't cleaned up the rest, now you know the drill you do it.
- Karl_oa
- 4 posts
