I made this fractured ground simulation. I want to export only last frame as an obj so I can import to Maya. How can I do that? I'm really new of Houdini..and I can't find the way
Locate your DOPNet import geo node and dive inside. Drop down a Geometry ROP Output node and set the filename to .obj extension. You can typically render out the current frame or a series of geometry frames using this node.
Using Houdini Indie 20.0 Windows 11 64GB Ryzen 16 core. nVidia 3050RTX 8BG RAM.
