default opengl lights in houdini
   8098   5   2
Is there a way to get the opengl view in houdini to use the “default lights” instead of lights in the scene? If I add a couple lights, I find the viewport slows way down. The only way to get it to full speed is to delete the lights. Also, I tried lowering the dimmer to 0 but that just makes the view black. Any suggestions?
Only through a hotkey (initially unbound).
Settings > Hotkeys…
You'll find it as:
/Houdini/Panes/Geometry Viewers/Toggle Headlight/Object Lights lighting
Thanks!! Is there a command that can do this through the textport?
Ondrej
Settings > Hotkeys…
You'll find it as:
so you can't get to that option any other way?
yikes!
what other gems are lurking in the hotkey dialog..?
-k
dziegler
Not as far as I know.
thekenny
yikes!
This was an exceptional case, as far as I know, and will be exposed in 9.0.
help vieweroption
Training Lead
www.sidefx.com
