Has anyone figured out how to add an offset to the curve solver?
For example, let's say you have a joint chain that's shorter than the curve itself. Is there are way to make it travel along the curve?
Curve Solver offset? (KineFX)
4072 9 1- shareware
- 40 posts
- hektor
- 54 posts
Have you checked kinefx_tools on git hub:
https://github.com/kamilhepner/kinefx_tools [github.com]
I was showing something that you're looking for there is a handy HDA for that.
Cheers
Cheers
- shareware
- 40 posts
- shareware
- 40 posts
After having a play, I don't think that HDA actually does what I'm after. I need the joints to continue to fit the curve as it is offset. Maybe I'm missing something with it.
Does anyone know of any alternatives? I'm basically rewriting a naive curve solver to do this which probably isn't ideal, but at least I understand what's happening under the hood that way.
- hektor
- 54 posts
There is an issue in the video where I connect it in the wrong way I believe
This is how it should be connected:
0 Input: Your solved spine
1 Input: Stashed original spine
2 Input: Stashed solved spine
Also, you can take a look inside of it. Applying offset is a very simple matrix operation.
Edited by hektor - Jan. 18, 2021 22:04:00
- shareware
- 40 posts
Hey Hektor, thanks for your help.
I've attached the setup you've described. Maybe I'm being dense but it doesn't seem to output correctly.
What I'd be after is a simple "U" slider on that HDA that would slide the solved joints along the curve.
I don't see how taking the pose difference between between the unsolved stash and the solved one helps with that. Doesn't that just apply a simple transform to every point?
- hektor
- 54 posts
- shareware
- 40 posts
No worries - I've pretty much solved it with some help from odforce. Though it might be quite slow. I save the joint lengths as an attribute , then use them with primuv() to fit each point using an iterative method. You can plug in an offset in the midst of that.
Wondering now whether I need to convert these fitted points to local-rotations down the chain. Need to test if it's required over simply translating the joints.
Edited by shareware - Jan. 20, 2021 06:07:54
- hektor
- 54 posts
- shareware
- 40 posts
