Hi. on the assignmaterial LOP in Solaris you can change the primitive to geometry or mesh amongst others. What is the difference between geometry and mesh. I was to tag geometry meshes (pols, sub-d etc. Is one preferred over the other?
EDIT: is seems MESH tags poly/subd data, but I still do not really understand what the difference in definition is.
Best
Mark
assign material: difference between geometry and mesh
2980 2 1-
- Mark Wallman
- 821 posts
- jsmack
- 8380 posts
- mtucker
- 4589 posts
"Geometry" would include curves, points, cubes, spheres... The reason "Geometry" uses UsdGeomBoundable is to capture point instancers (which are boundable, but are not gprims). If you go to https://graphics.pixar.com/usd/docs/api/class_usd_geom_boundable.html [graphics.pixar.com] and click on the "Inheritance Diagram for UsdGeomBuondable" it shows a nice graphical representation of the schema inheritance.
