using KineFX skeleton for path orientation
   2839   3   0
Hi All,
I'm working on a model made of a twisted ribbon - I was wondering if there's a way of using the skeleton/rig pose toolset for setting point orientations along a path?
Basically I would love the per-point orientation handles without the hierarchy.
Is there a simpler way where I can modify the @orient attribute directly with a handle?
...because this ribbon will be quite long, with a lot of twists, using the rotation ramp will be impractical.
Interesting question! Here's a quick attempt, basically delete all the heirarchy, rigpose, and skeleton blend back onto the original curve.
kinefx_rigpose_curve_no_hierarchy.hip (212.9 KB)
Thanks Matt!
...I was given a very easy solution via the discord group:
simply use the edit node:
first add an orient along path, then edit node in local space + recompute normals disabled.
I was overthinking it with the skeleton setup.
9d9KrGOpNH.mp4 (4.4 MB)
Overthinking solutions is the Houdini way.
