Hi.
Image that there is a vellum start simulating at the beginning of the scene.And I'd like to stop the simulation at a certain frame and then extract the current geometry to use as something others (like turnning it into a no-simulation object or a dynamic fracture object or so).
Is there an efficent way to achieve this? Thank you so much.
How to stop vellum simulation at a certain frame?
1782 1 2- huangyu2
- 2 posts
- Berk_Erdag
- 86 posts
If I understand you correctly, you can just put a timeshift node after the vellum sim. Inside the timeshift, delete the expression in the Frame and set it to the desired frame number.
Or maybe you can sim your vellum simulation and put a file cache after it. Write the desired frame to the disk. Then you can load it and start working on your model.
