Function does not work on Multiparm
   1026   1   0
There is a function in hou.Parm [www.sidefx.com] called containingFolders() that is meant to return "a tuple of strings corresponding to the names of the folders containing this parameter."
However, if the parameter is inside a multiparm block, the result is an empty string.
Here's how I've set it up:
Type Properties > Create Multiparm Folder (give it a name like mpFolder) > Create a Button in that folder
Go to the Scripts tab, Create a Python Module and paste the following:
def Func(kwargs):
    parm = kwargs["parm"]
    print parm.containingFolders()
    print hou.Parm.containingFolders(parm)
Go back to the Button you created, callback script: kwargs.hm().Func(kwargs)
I'd expect clicking the button would return something like ('mpFolder'), since that's the folder that the button resides in, but it just gives () instead.
Is this a bug or am I doing it wrong?
Edited by Jikian - July 30, 2021 01:30:32
I did it wrong, the correct class to use is ParmTuple [www.sidefx.com]. Call parentMultiParm().name() to get the parent multiparm folder's name of a multiparm instance.
