setting the position of a named bone of a kinefx skeleton
   2349   3   0
Risking redundancy, I posted this same topic on odforce. Hopefully someone on this forum can give me a some help.
I've managed to create a kinefx skeleton rig for a quadruped character.
Each bone is uniquely named as is recommended
I'm trying to set the position of one of the kinefx skeleton bones to the centroid of a group of points in the mesh geometry being deformed
I'm using the "getbbox_center(0)" vex function to acquire the centroid but I cant figure out how to set the bone position to that vector position value.
I was hoping to use a rigattributewrangle sop node to set the position of the bone but the syntax to accomplish that is not easy to find.
Help would be appreciated.
WillA
maybe you can start by using Rig Attribute VOP
you can use Set Point Transform VOP to set transform of any particular joint by index or name
then you can observe it's code if you want
in wrangle it would be something like
vector P = {0,1,0};
string name = "myjointname";
matrix xform = ident();
translate(xform, P);
int pt = nametopoint(0, name);
setpointtransform(0, pt, xform);
Edited by tamte - Oct. 6, 2021 11:39:07
Hi Tomas,
Thank you so much ... the wrangle code worked perfectly.
I searched all over the internet for this syntax.
I hope you don't mind my asking.
Where did you find this kind of detail on accessing the kinefx skeleton?
(I will explore the Rig Attribute VOP for personal growth)
as Thomas was saying, you first create the nodes in a rig vop, then right click the rig vop and vew as vex code.
