Simple modelling question
2323 6 0-
- sarahjenkins
- 22 posts
Hi, I'm modelling a character at the moment and just landed at the current part, the helmet. I was thinking of extruding the stripe part inwards, but wondering what might be the best approach for this?
My blender brain is saying just bring it into blender and sculpt, but I'm trying to stick to only using houdini at the moment. Currently I'm dealing with a quad-based helmet. Should I try and manipulate the points I have available (then poly extrude), or should I try more of a boolean/vdb approach?
It's the curve of the stripe that my brain can't seem to figure out.
Any pointers would be very much appreciated!
- FaitelTech
- 114 posts
- robsdesign
- 240 posts
Hi, I expect there are better methods but I've attached a hip file showing one way of doing it.
This uses a quad sphere (or you can use the Labs sphere generator). I've manually selected edges to straighten, inset a group for the cut and extruded inward. Use a fine bevel to sharpen edges and use subdivide for the rounded corners. Slide points near the corner to alter the roundness.
Rob
Rob
- sarahjenkins
- 22 posts
- sarahjenkins
- 22 posts
robsdesign
Rob
This is so great, and exactly what I was after. Thanks so much for taking the time to look at this for me!
- FaitelTech
- 114 posts
- sarahjenkins
- 22 posts
I'm curious how solve the task in Houdini too.
