Hi
I love the new fileCache node, but I have a question regarding batching of saves.
First, the vanilla new filecache node implies that there is a difference in saving if you are dealing with a sim or not, as there is a "simulation" toggle. What does this do exactly? I don't see any difference when I save whether it's on or off. I assume this would allow you to run multiple concurrent saves in the BG if it's off, but I don't see this happening nor do I see any way to control the number of instances spawned.
The LABS file cache does seem to do this properly, but when I run a non-sim cache in the BG, the TOPS interface does not update to reflect the fact that there are four caches going on the the BG. Is this a bug or limitation? Attached is a screen grab where you can see the four processes in the shell, but nothning indicates this in the node itself.
Sean
New file cache node and LABS file cache node
862 0 0- mrCatfish
- 731 posts
