I seperated my scene each other have velocity motionblur. When I combine these, There is some boundary at between in Nuke. How can i do for remove the boundary?
Use a Plus instead of an Over. When layers are mutually held-out, the background layer is already pre-multiplied by the front layer's alpha complement. Using an Over pre-multiplies it again, resulting in an edge. Plussing it combines the layers as if they were samples in the same render pass.
jsmack Use a Plus instead of an Over. When layers are mutually held-out, the background layer is already pre-multiplied by the front layer's alpha complement. Using an Over pre-multiplies it again, resulting in an edge. Plussing it combines the layers as if they were samples in the same render pass.
