Is it possible to get bake results from python api when running python script as a commandlet?
I'am using a python script based on what is described here:
https://www.sidefx.com/docs/unreal/_public_a_p_i.html#PublicAPIPyAsyncProcessor [www.sidefx.com]
(script at the end)
When running script.py in unreal editor (5.0ea2) itself I get the bake saved.
But if run the scirpt as a commandlet it just runs and no errors but no bare results and no hars spawned no callbacks on ProcessHDAExample called (on_failure or other). That is how I run the script as a commandlet:
#.\UnrealEditor-Cmd.exe "myproject.uproject" -run=pythonscript -script="script.py"
The hda is just a file input sop with file path to bgeo exposed as param.
Thanks in advance.
----------------script---------,
from time import sleep import unreal from HoudiniEngineV2.asyncprocessor import ProcessHDA _g_processor = None hda_path = '/Game/HDA/import_utils.import_utils' def make_parameters(): parameters = {} parameter_tuple = unreal.HoudiniParameterTuple() parameter_tuple.string_values = ("path to bgeo",) parameters['file'] = parameter_tuple return parameters class ProcessHDAExample(ProcessHDA): def on_failure(self): unreal.log_error('on_failure!') global _g_processor _g_processor = None def on_complete(self): unreal.log_warning('on_complete!') global _g_processor _g_processor = None def on_post_processing(self): unreal.log_warning('on_post') def run(): # Create the processor global _g_processor _g_processor = ProcessHDAExample( unreal.load_object(None, hda_path), parameters = make_parameters(), enable_auto_bake = True, bake_directory_path = "/Game/HDA", remove_output_after_bake = True, replace_previous_bake = True, delete_instantiated_asset_on_completion_or_failure = True ) if not _g_processor.activate(): unreal.log_warning('Activation failed.') else: unreal.log_warning('Activated!') #i = 0 #while _g_processor: # sleep(5) # i+=1 # unreal.log_error("tik tack {}".format(i)) if __name__ == '__main__': run()
