How to set condition
   2344   4   1
Hi guys,
I need to set condition based on a wedge attribute to set an other wedge, how could I set this?
Thank you for help
Wow factor
You can refer to wedge attribute values using the @attrib syntax or the pdgattrib(..) function in an HScript expression. For example, @scale.2 or pdgattrib("scale", 2) will both access the "scale" attribute at index 2.
On the wedge node itself it's possible to change the Wedge Type from Range to Value. You can then type in an expression that uses other prior wedge attributes to control the value.
COuld you share a simple scene with wedges please? I can't get it work with attributes in interface.. SOmething I'm doing wrong for sure...
Wow factor
I've attached an example with a wedge that randomly creates one attribute, and then creates another one derived from the first one. I also included an example of how you might use the Split node based on a wedge value to separate out work items that match a condition.
wedge_example.hip (96.1 KB)
Thank you very much Tpetrick!!
Wow factor
