How do I select points based on their colour?
   4757   4   1
Hi all, how would I select and group all of the 'blue' points/vertex colours on a mesh? all help appreciated!
Dave
You could try this inside a point wrangle.
// Using 0.9 instead of 1.0 to allow for a little error in the color.
if(v@Cd.b>0.9){i@group_all_blue = 1;}
NOTE: This wont "select" them in the interface, but it will add them to a group you can perform operations upon.
i@group_ is a built-in mechanism for assigning points/prims to groups. The group generated is not named "group_all_blue". The group the code will create is called "all_blue".
The flaw in the above code is that points with other red and green content might be included. You can extend this with more code checking...
int no_red = 1;
int no_green = 1;
float threshold_low = 0.1;
float threshold_high = 0.9;
if (v@Cd.r<threshold_low){no_red = 0;}
if (v@Cd.g<threshold_low){no_green = 0;}
if (no_red+no_green == 0){
    //Time to check for blue.
Edited by Enivob - March 5, 2022 15:01:33
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Strikes me that this shouldn't require vex. I thought maybe I could use the attribute adjust colour node as a basic keyer, isolate to a range of blues and export as a mask, but it doesn't quite fit the bill. Looked to see if there was something hiding in the 'mask by...' sops, but couldn't see one.
Worth an RFE? Or is there a method I'm missing? I think a 'mask by colour' sop or mode within mask by attribute/vector could be really handy.
Thank you both for taking the time to reply. I really need to spend some time to learn VEX!
Thanks again!
You could also use
@Cd.b>.9
in a group expression SOP. There really should be a lot more examples in the dropdown of this SOP, (this being one of them).
Sean Lewkiw
Machine FX - Cinesite MTL
