Hello everyone.
I'm working on a procedural piece of furniture. I want to instance a weaving pattern on some panels using for each primitive.
For this, I tiled a mesh so that it overlaps each panel. This works well, however now I want to clip the instanced mesh to each panel...
How should I set my "clip" node in the for loop so that the clipping happens per panel? I cannot use boolean as this is an instanced mesh... Any suggestion?
Thank you very much.
Alain
Clipping instances in for loop
871 0 1- Tomahawk-573
- 10 posts
