Mantra: AOV per light multiplies volume rendering time by 20 SOLVED
3016 9 1-
- Tanto
- 546 posts
- jsmack
- 8188 posts
- Tanto
- 546 posts
- tamte
- 9428 posts
I havent seen that with lights
but I noticed something similar with Emission AOVs and volumes, not sure if that's your case
since emission AOVs by default are Full Opacity Sampling and that for some reason slows down rendertime when rendered together with lit density
rendering density and emission separately is fast even when emitssion render is held out by density, I didnt have time to investigate why, but this is in 18.5
- Tanto
- 546 posts
- tamte
- 9428 posts
TantoI mean quick try would be to change emission aovs from Full Opacity Filtering to Opacity Filtering but that would use stochastic sampling and may be grainier, however if it speeds up you'll know your culprit
Yes I did have an emission AOV. Thank you, I'll try rendering just that separately. And this was in 19.0.498.
rendering separately was fast for me for emissive volumes even without stochastic sampling
Edited by tamte - March 25, 2022 16:59:15
- Tanto
- 546 posts
- jsmack
- 8188 posts
tamteTantoI mean quick try would be to change emission aovs from Full Opacity Filtering to Opacity Filtering but that would use stochastic sampling and may be grainier, however if it speeds up you'll know your culprit
Tanto
Just the "Combined Lighting (Per-Light)" and "Combined Emission" image plane presets. No tags.
Combined emission is a no-no. It should never be used with volume rendering as the direct component requires full opacity samples for quality, and the indirect component should be done with screendoor samples for performance.
Using the combined plane requires a compromise.
- tamte
- 9428 posts
jsmackah, that makes sense
so having direct_emission at Full Opacity Sampling
and indirect_emission at Opacity Sampling
should work fine and in fact that seems to be the default for those AOVs
Edited by tamte - March 25, 2022 17:44:24
- Tanto
- 546 posts
