I have a data set that I can turn into a curve(red). Which has mostly low values, but a number of points hockey-pucks to really high values.
I want to be able to map the red curve onto the green curve, which is a more gently sloping positive curve.
If I normalize the curves from 0-1, is there a way to look up into the red curve (curve U attribute), and get the corresponding Y value on the green curve (at the same U attribute position)?
How To Map One Curve (Data) onto Another?
1216 4 2- jlapre
- 132 posts
- Digipiction
- 166 posts
- jlapre
- 132 posts
Thanks, Digipiction.
I neglected to clarify the lookup mechanism I need:
For a point on the red curve's Y value, return the green curve's Y value with the same curveu index.
i.e. I need to look up: for a point on the red curve with a specific Y value, how do I get the corresponding curveu?
Edited by jlapre - March 28, 2022 11:43:12
Jeroen
- Digipiction
- 166 posts
I'm sure there's a mathematical solution, but you could probably put a grid at the Y value so that it intersects the red curve, then do an intersection analysis or a boolean to create a point there and read its curveu.
Another way would be to resample the red curve heavily (give it a ton of points), then scale it to 0 on both X and Z so that it points straight up from the origin. Then find the closest point to your Y value:
int n = nearpoint(0, set(0, yValue, 0));
float curveu = point(0, "curveu", n);
- vinyvince
- 255 posts
I will give a try with Uvsample(), Uvdist()
Edited by vinyvince - June 16, 2023 16:27:07
Vincent Thomas (VFX and Art since 1998)
Senior Env and Lighting artist & Houdini generalist & Creative Concepts
http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
