LOP Instancer Copy Custom Point Attributes
   2229   3   0
hi!
I got a problem about LOP Instancer.
if i set "Target Points Location Source" to "First Input's Points",it dosen't copy any attributes except pscale and orient.
i can use LOP Copy Property to fix this,but I don't think it is a best way.
so,How did you solve this problem?
Edited by ccyzkk - April 12, 2022 08:37:40
ccyzkk
That probably is the best way. The instancer only copies attributes from sop points.
Thanks jsmack!
I had similar issue and solve it by copying everything inside the instancer LOP
