Is there a way to alter the stiffness of ik joints so that the movement is delegated to certain joints of the IK chain, while others remain stiffer. Is there an attribute for this purpose? Especially for IK chains which a longer than a regular leg.
Cheers
Tom
KineFx IK joint stiffness
1196 6 2- Tom Mangold
- 96 posts
- cwhite
- 733 posts
- Tom Mangold
- 96 posts
Thanks for the tip!
Currently try it, but so far without success. My IK chain is made up out of 6 joints. Right now I have the impression that the KineFX IK solver puts all the deformation in the UP joint. All other joints seems to be stiff. Is there something wrong with my set up or is the solver not able to distribute the rotation along all joints?
Cheers
Tom
Cheers
Tom
- cwhite
- 733 posts
- Tom Mangold
- 96 posts
- cwhite
- 733 posts
I think we were talking about different SOPs - I was referring to the Full Body IK SOP, not the IK Chains SOP. From the IK Chains SOP helpcard, "This SOP allows you to quickly setup two-bone IK chains", so that is not the solver to use if you want a longer chain where each joint can be adjusted individually by the solver
- Tom Mangold
- 96 posts
